1 - 2 of 2 Posts
Anyone else have this many problems with there reproduction brake / clutch pedal & linkage kits. - Frame bracket for z-bar completely wrong, push rod too close to brake pedal & now the push rod bracket that was welded to the clutch pedal snapped off at the spot weld point. Any other items I should reenforce while I'm in there?
I had pretty much the exact same problems. Had to trim to clear the push rod, and had to ditch the frame bracket and get an original. Also, i had to put my adjustment rod on the other side of the z-bar so it would line up with my clutch fork...talk about a headache.:clonk:
1 - 2 of 2 Posts
