Hey guys, a buddy of mine owed me some money and offered to settle the debt with a brand new pair (bare) of iron Pro Topline 083 (or L98) replacement heads (never out of the original boxes). Since the debt was under $200 and the deal included brand new set stainless 1.94/1.5" valves, .600" lift springs/retainers/locks, and PC viton seals.
I accepted figuring that they should make a decent head for a mild 355 rebuild, 9.5:1 CR Speed-Pro hypers, Summit 1103 hyd cam (.442/.465", 214/224 [email protected]", 112 LSA), Performer RPM intake/Q-Jet, going into my 5500 lbs K5 Blazer w/4.11 gears, 700R-4, 33" tires, 1 5/8" headers, 2.5" dual exhaust (UltraFlo Race Magnums).
Anyway, I just looked over them and except for some minor flash under the exhaust seats (flashing where the seat meets the unmachined area) they seem to be nice heads. The flash is nothing a carbide bit and 5 mins with a die-grinder won't fix.
Some of the nicer things I've noticed over stock heads are thick decks, large and smooth water passages, machined for screw-in studs and guideplates, slotted pushrod holes, high valve cover rails, and come already machined for PC seals.
I have to say that was really suprised how clean they are in terms of casting flash in other areas. I've own a few sets of World Heads and they always required a decent amount of time to clean up all the flash on them right out the box.
I will be dropping them off at the machine shop sometime this week to have them looked at by a pro mainly due to the rumors I've heard about the guides being off in these heads right out of the box. If the guides messed up, I'll just have the guides machined for a complete bronze replacement (not liners) which I am half tempted to do even if the cast iron guides are fine.
So, I am wondering what you guys think? I know Pro Topline hasn't always had the best rep, but how bad can these really be? Do you think they might benefit from some sanding rolls and port matching to a Fel-Pro 1205 gasket?
Any other thoughts or suggestions?
Thanks guys!!
Thanks guys!!
