1967 Chevelle SS true 138
I’m looking for some information on pro charger fitment. I’ve got a 1967 chevelle true SS and it’s original besides the engine and rear sheet metal is currently getting replaced too.
Here is where I need help.
I’ve got a 454 that I am turning into either a 496ci or a 505ci. I’m going to build the engine to about 575hp and I would like to put a pro charger F1A-94 on top of it. My only thing is that I want to keep the original SS hood.
I know I could probably get away with using a standard pro charger hat over my Holley sniper, but an f1 really would be restricted by that and I’d have to push the charger harder to get the 850-900hp mark that I want. I more so need the 4” competition hat that they offer.
Has anyone done this and succeeded? If you have any advice or knowledge, that would be appreciated!
Not much Room under a 67 Hood with a BBC in it
My 454/468 ci with a the following on it just fits under my Hood
  • INTAKE Manifold Weiand Stealth Hi Rise Dua lPlane 4150 Carb Flange/Sq Bore/OvalPorts# 8019
  • Moroso # 64943 Carb Spacer Phenolic & Plastic / 4 hole plenum design / ½” thick
  • Carb 950 Holley Ultra XP # 80805RDX Height ??
  • Spectra Ram Air Cleaner Low Profile 2.5" Height above Carb
SO Carb Height = ?? + 1/2" Spacer + 2.5" Hi Air Cleaner = 3" +++
712155
712156
712157
Hope this helps
Reactions: Daniel67SS
Hope this helps
Thank you sir! That’s exactly what I needed. I guess I might just have to build a more aggressive NA bush block for it.
