I borrowed a friends 1800 psi Karcher (K 3.68M) electric pressure washer to clean my deck in prep for stain & sealing. After about 20 minutes of continuous use it simply stopped working. Friend said it does that all the time and just keep the wand trigger depressed until it comes back on. I kept it pressed until I got cramps but it never came back on.
I did like it though so while his was taking a break, I bought the same unit. Working along fine, took a break after about the same time or maybe longer, and, well, it won't work just like the first one. Depress the wand's trigger and nothing happens.
Brought his back out after sitting for about 6 hrs. and it worked until - you guessed it - the first time I released the trigger. Then, nothing.
Both units were plugged into different outlets, no house breakers being tripped, test on both unit's plugs are fine. Is working them 20-30 minutes at a time just working them too hard? Anyone have similar troubles with the electric units?
