I will be cleaning, prepping and painting the rear end differential housing and rear drum backing plates sometime next week.
Any tips or advise would be appreciated.
I am planning on pressure cleaning it, then hit rest of it with wire brush and cleaning fluid (mineral spirts, gunk, etc). Maybe sandblasting if necessary.
Is there a particular primer to use before painting?
What paint to use? POR-15? and then a top-coat?
Do the brake backing plates get painted with the POR-15 also or should I spray them with a high temperature gloss black enamel? Should I use the same paint on the inside of the backing plates, where the brake shoes press against?
Also, I am assuming that I need to remove the rear cover and cut in the paint around the housing. Let that dry then re-install the cover after that has been painted. Does that sound correct?
Are the brake drums correctly painted metal grey or should I use same gloss black on them?
Thanks for the help!
