I am tired of the open differential in my '68 12 bolt picking one wheel to spin. I have been cosidering a posi unit, but I don't want to hassle with the ring/pinion re-set up, etc.
I saw these Powertrax lockers in the Jegs catalog, and called the company company direct. They have one called a 'No Slip', which is supposed to be good for road use because it actually does 'slip' for turns. However, in high load situations (burn outs) it will lock and deliver power to both wheels equally where a posi could have more power (and speed) going to one wheel causing fish tailing.
It simply replaces the spider gears and fills the opening in the differential case without messing with the ring and pinion. At about $400, it sounds too good to be true. Anyone seen one in actual use?
I would call my application pretty light duty, about 1500 miles per year with a few wheelspinning starts thrown in.
