1 - 2 of 2 Posts
I have a 70 Chevelle with power windows. All the windows work when I use the master switch on the driver's door, but when I use each individual switch, nothing. I couldn't find a hot wire when testing the individual switch.
Should I troubleshoot each individual switch or start at the master switch? How are each switches wired?
Sounds like the 12 volt input feed line is dead on the switches. Each switch is fed by a red or red white wire that provides 12 volts to the switch. I'd stay with the front 2 switches (for starters) and see if there is 12 volts to both feed lines. Sounds like you have it on the drivers side but not the passenger's side.
1 - 2 of 2 Posts
