Adding a little to this great write up. Finally acquired a set of power locks and window regulators from a 71 Buick Skylark flat roof wagon. Was unable to get the complete harness for either but have enough to make all the connections on both sides of the boots and to power. The fuse box on the wagons with the both power windows and power locks contain 2 large circuit breakers, if only one system is installed there is only one breaker. I did not take any of that, will be using an AAW Classic update harness so the factory power connectors will not be needed.
All the holes that need to be drilled in the doors and body for both the locks and windows are dimpled to mark the locations and for the regulator mounting in most cases already exist.
For the door boots the holes in the body are 2.25" in front and 1.25" in rear. Hole sizes for the doors are 2.0" front and 1.5" in rear.
My wiring will be real simple, no switches in any of the doors. One 4 gang in the console for all the windows and another single switch for the locks. Front seat passenger can reach the switches, back seaters most time will be grandkids that do not need access to them
Also going to add rear door dome light switches and add a second dome light over the cargo area.
