As indicated by my first post, no pictures should be needed (because I've asked in the past and nobody had any) But if you center your switch in the FACTORY hole where the window crank used to go through this is where the switch mounts. For the single switch panels, just take a razor and square off the hole until your switch and retainer fit, and on the driver panel center the switch on the hole, then elongate the hole in each direction until it is a rectangle and your switch and retainer fits, and Wallah! you're done
