1 - 2 of 2 Posts
Well, I was out messing with the power windows in the Benz and now I can't get one of the windows up. It goes down fine, but try to go up and it blows the fuse. Now it's stuck down and I don't know how to get it up? Any ideas? The switch is good, and the other windows work fine....
1969 Caprice 4400LBS!!
454/M-20
12-bolt 4.10 Posi
13.45 @ 105
323HP @ 5200RPM
382lb-ft @ 3300RPM at the wheels!
Andy and Nick's Muscle Car Half-way House
Sounds like the window is binding up somehow, or the spring in the regulator is broken. Can you pull up on the window while pushing the window switch up, to make the window go up? The spring acts like a counter-balance to support the weight of the window, if it is broken , the motor probably not strong enough to lift the window.
1 - 2 of 2 Posts
