So While waiting for the weather to warm up Hahahahaha I thought before putting th glass in all the way round on the car I wanted to look at putting power vent windows in it.
I know a little more weight.. But hey You only live once and long enough to enjoy what you make!
I have all the required switches to make the harness just not sure about wiring it.
I have a wiring diagram from a 64 Cadillac that shows the Power vent windows.
Figured I just use the front part of it and wire to the nearest relay which is the power seat? At least that is what the diagram says to do.
So my questions to the people in the know when it comes to wiring.
What gauge should the wires be?
Feeds should be larger gauge...?
Other wires like operational or directional from switches etc gauge?
Add it's own relay?
It shows it being connected to the Relay and we will use this one for the power seat...Or could I use the one fore the power windows which will be under the hood as Bill pointed out. Same as for a Power top? others have said it is behind the left kick panel?
The big question I have is there is a wire that goes to a 40 amp Circuit breaker?
The colour diagram shows the power going to the Fuse block so 12 volt power with the acc on. But the 40 amp breaker is it an inline or one I add or is it the Fuse block as well?
If I do add it where does the wire go after it hits the breaker to Ground?
Again guys and gals...wiring is spaghetti with no sauce to me....!
Grateful for your wisdom and assistance..
Not really worried about colour as coloured tape will do that for me if I should need it.
Casey
The black and white diagram shows the vent windows. Etc.
The colour diagram is for power windows but figured I could make the harness from the diagram using the front window Circuit and even add another relay if need be?
Add it's own relay?
Casey
