1 - 2 of 2 Posts
My 67 Malibu has a Ps problem. It has stock power steering pump. When I am parking or making a tight turn at idle the power assist will go away (not totally but will cut in and out) and become stiff to turn. The belts are new and do not slip and the fluid level is full. Is the pump shot? don't want to take chances because it has a fresh Ps box.
Thanks in advance
Hot66ss
Los Angeles,CA
66 Super Sport
67 Malibu
Aces Member 2380
Team Chevelle member #262
members.aol.com/chvellss
Administrator
It sounds like your belt is slipping even though you don't hear a squeal. After a new belt has run for a short time it should be retightened. This is easy to do. If this doesn't fix it look for a problem in the pump, the bypass valve or restriction in one of the hoses.
Philip Valentine
Gold Member #42 "Perseverance is not a long race; it is many short races one after another."
[email protected]
1 - 2 of 2 Posts
