Desperate help needed here. I'm trying to convert my 396 BB to Power Steering. First mechanic suggested I order the BB Conversion Kit from Summit Racing which I did but was shipped from CCP. This first mechanic closed up shop and I had to look for another mechanic. Second mechanic took apart all parts for the steering only to advise me I needed to change out the shaft, which he recommended I order and I did. When the new shaft came in about 40 days later I took it back to the second mechanic. The second mechanic took all apart again only to advise me once again, won't fit. I ask him to explain why and these are his words and I Quote: The issue with the power steering is the alignment of the pulley on the pump with the crank and also the alternator will be almost touching the top of the power steering pump when installed. I am not sure if there will need to be another pulley added onto the crank or if there is a different mounting bracket that is needed. Also not sure if the alternator may have to be relocated in order for it to fit safely. The third mechanic had this to say and quote: So I have been doing a little bit of looking around. I feel like you have 2 options. Option 1 you can move the alternator to the other side of the engine. This will require a different bracket setup. Option 2 you can go to a serpentine belt setup. Either way you will be required to purchase different things to make it fit right. I have enclosed 2 pictures to give you an idea of what I am talking about. I truly need some expert advise here. Thanks
