M
marvin
·Guest
I am thinking about changing out the steering box in my 65 Chevelle to a newer, quick ratio box. My question is, if I change to a newer box it will no doubt require power steering fluid, my old pump uses dexron. Do I continue using dexron or start using power steering fluid? Do I need to change to a later model pump as well? Any help would be appreciated.
