Just wanted to confirm that i have to change out my original power drum master cylinder if i upgrade to disc brakes? or can i just change the prop. valve?? i will reuse the orig. 11" booster...
thanks,
andrew
my master cyl. is a dual bowl? for power drum brakes... original set up... so what would the difference be between the two? my master cyl appears to have 2 equal sized resevoirs...
ak
For one thing, the bowl that feeds the disc brakes doesn't have a check valve in it. I just bought a new one for mine and the cost was only $40. Jim
thanks, money isnt the issue, i just like the looks of the orig master cylinder vs. the fatter round looking disc brake one you see in the kits... just wondering if there was a difference... i'll prob. end up buying a complete swap kit...
thanks,
ak
