1 - 2 of 2 Posts
Remove the check valve from the booster for a second and put it back again, to get rid of any remaining vacuum in the booster. Hold the brake pedal down and start the car. If the booster works, you should feel the pedal moving down a bit as the vacuum builds up and the booster starts applying pressure to the system.
1 - 2 of 2 Posts
