Where is the best place to install the vaccuum on a power booster, back of the carb or on the intake manifold. Does one have more vaccuum than the other or are they the same. I have either place. I just want to put it in the best spot. Thanks.
GM generally put it on the big port on the back of the carb, but if you've got a PCV valve going there, then just going to the manifold where GM put the heater and trans vacuum modulator lines will work fine.
1 - 2 of 2 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
