Hey Guys. :waving:
I'm kicking around the idea of doing a 540 build. Don't want to break the bank, but I don't want to do a halfa-- job either. :noway:
My thought was to reuse many of my current components on my 496 along with a Dart block and new pistons. I would shoot for around 10.5 scr (pump gas). I may reuse my solid roller (see specs in signature) or something similar with more lift and maybe a little more duration(maybe a Strauby cam :thumbsup
. The Pro Systems 1000HP would be reused along with a fully ported Victor Jr. I would like to reuse the current 2 inch headers (if possible).
The big question is my heads. They started out as 294cc rect port Race Rites. They have been ported by Mike stark of CFM with his Stage 5 porting (see attached link below for additional head detail). They flowed 384 and 250 @.700". After porting intake runners are now 310cc. I dont really want to replace the heads. I'd like a combo that makes peak power around 6200 to 6300 rpm and hold on for a 6500 to 6700 rpm shift. Is this possible with these heads and headers? Will this be a turd up top? I wouldn't mind seeing a 750fwp dyno sheet. Is it doable?
Thanks in advance for all your comments.
http://www.chevelles.com/forums/showthread.php?t=372437&highlight=dyno
http://www.cfmperformance.com/services
