This 66 also has the removable steering shaft flange. I hate fluid running all over. And the possibility of fittings not sealing up after removal. They don’t leak now. Can I get the rag joint out to access and replace the seal.
I was just referring to how I put the plastic around the Power Steering Pump shaft in referance to use the same process on the steering box when you replace the seal. I never replaced a seal on a steering box but figured it would probably have a sharp edge on it too. The one thing I didn't ask is the steering box mounted up towards the front of the frame on a 66 like it is on a 71.Thank, I thought this might be possible; but didn’t want to try it to only find out it was not possible. On the plastic use for the shaft, I think you meant sector shaft not pump shaft, right?
