The previous owner cut my positive coil wire very near the fuse box. And now that I'm back to points, it smokes when the power is connected. This is BAD. Can that single wire be replaced easily or could I run a wire from a constant hot spot on the fuse box to a switch, which then goes to the ballist resistor and then to the coil? Which would be the easiest/wisest option?
