Allright it is confirmed (talked to a few local diff guys) My chunk is junk! from spinning inside my case (pinion grinding on it) They also advised not to try this project by myself (replace gears rebuild etc.) Local guy is coming out to my house once all parts accumulated. Brings me to this question: Posi or non-posi? Diff guy here says if your not going to drag etc. posi not needed, says car will skip/hop doing corners etc. He recommened going non-posi and a 3.73 gear. Your guys thoughts?? Also have found a part number #3869788 it is a regular non-posi spider gear diff set, guy says it is for a series 2 12 bolt carrier. I believe I have a series 3 (non-posi stock 3.31 1967) are these parts compatible??? Add said it would take a gear spacer??? to fit gears - not sure what that meant?? will ask. Input appreciated
