the guy i bought my 68 chevelle from gave me a box with the number 910-48602 and it says speedway motors.On the description tag it says mini spool 65-70.
the guy i got it from told me it was the posi gears and if i wanted to put them in i could but it would be a bi**h to drive around town especially when turning corners.but!!!some one else told me that they didnt sound like a posi that a posi was a differential or some crazy term like that!!it was awhile ago!!
THE DESCRIPTION:it has two big cogs,two big shims,two small cogs and two small shims!!is this a posi if so would it be o.k to run on the street.one of the small cogs is kinda worn alittle on the surface between each grove is it bad?????i have just the stock rear gears a th350 and 383.what do you guys think??
i dont know anything about gears and trannys,ratios etc.....whats up and any tips that would increase perf would be great appreciated?
also what are the biggest gears you can run on highway runs without killing your car??????cause i heard if you run bigger gears itll kil your engine???
[This message has been edited by mykes68 (edited 09-22-2001).]
<BLOCKQUOTE>quote:</font><HR>Originally posted by mykes68:
<HR></BLOCKQUOTE>
You've just answered your question, A mini spool, not a posi unit.
A posi unit allows for slippage of the axles in turns and a spool locks the two axles together, thus the hard turning
so what you are saying is that this isnt a posi,that it is a device to lock the rear wheels so the only difference is that a posi allows slippage of the axles when turning and this keeps them locked all the time???
is there more differences between the two?
wouldnt this "minispool" be better for strip runs than a posi?or no??
Mini spools are designed for dirt track racing. They are dangerous on the street because the break parts and can cause you to loose controll of your car. They can be used for drag racing, but not for real strong cars. My advice is don't use it! Get a Eaton posi and you will have no problems out of it.
