Cars running great but I can’t leave it alone 🤣😂. Skipped port matching the intake. During my build. Decided to try to extract more power. Heads are BTR/TEA Trickflow 235’s. Kinda shocked how far off the port is. First couple pictures are stock fast. Red arrows are problem areas. One side does line up really well and will not be touched. Will plastic weld the area at the bottom left of each port and a little up the runner. Don’t want epoxy inside the intake possibly coming loose and destroying the engine. Used a hooked razor blade to mark the bottom side of the fast with the lower shell bolted into place.
3rd and 4th photos are with a little porting
