1965 Chevelle SS 327 4 spd
I recently had my my 65 327 short block rebuilt and stroked to a 350. The reason I did this is because it was burning alot of oil but otherwise running fine.
After I recieved the short block I put on new Edelbrock heads, a new Comp cams 270 mag cam, roller rockers, L-79 intake manifold and Holley carb.
After putting the engine in the car and waiting months to get my car runnning again I fired it up. Now a get a very pronounced popping/pulsating coming from the exhaust pipe. Its loud. The engine seems to run fairly smooth otherwise, except it really pops when you rev it up a little and let off.
It sounded like I have a bad camshaft to me, but everyone I have talked to thinks its a sticking valve, bad muffler(both are near new and worked fine before) or improperly adjusted valve lash.
I am now checking everything out, I started first with a leak down check of all the cyls. On the drivers side everything was looking good until cyl no 7. I never get both valves closed at TDC on the compression stroke. The exhaust valve is well on its way down. Hmmmm Could this be a bad cam? Has anyone ever experienced this before?
Bill
[email protected]
through the drivers side exhaust pipe.
Bill
[email protected]
