Am I doing something wrong?
I’ve a 1.375” Hotchkis sway bar on the front of my 66. During the course of trying to find a load creaking noise I decided to put lighter springs in the front. I had always thought it was to stiff for me as a daily driver anyway. As I was removing the sway bar I noticed it did not move freely in the bushings. I had to put almost all my weight into it to get it to even move.
After I get the new springs in I drove around a bit to get the springs to settle without the sway bar: noise was gone.
So it was the springs (which I just changed) or the sway bar I had not yet put back on.
The poly bushings that were on the sway bar were pumped full of silicone grease. It was coming out of both sides of both bushings.
When I pulled the bushing off I noticed the grease was super tacky. Almost like a weak glue. The grease was in all of the bushing grooves but not slippery at all.
I called Hotchkis and they said poly bushing are noisier but properly greased you shouldn’t hear them. They also warned me not to mix greases.
So I cleaned everything up, regreased it and put it back on.
Noise is back. It’s really load now too.
So it has to be bushing sticktion.
Anyone else get this?
What grease did you use?
Hotchkis said silicone or moly- no lithium.
I’ve been using silicone.
Help!
Help!
