Hey Guys,
#1- I need all the help I can get hear. I have been posting and searching on front rebuild kits, and I am going with purchasing all the hard parts either moog or napa. Plz add to my list o things that I need number of and part. Thanks guys for the help.
#2- PS. My Chevelle has a front sway bar however it does not have a rear sway bar which I would like to get. I have a 12 bolt rear end what other parts will I need in order to install the Rear sway bar?
Example:
Center Link x 1
Adjusting Sleeve x 2
Tie rod end x 2 Outer
Tie rod end x 2 Inner
Lower Ball Joint x 2
Upper Ball Joint x 2
front Idler Arm x 1
Bushing Kit x 1 Lower control arms are oval in the rear
Set of Springs Front and Back
Set of Shocks Front and Back
Set of sway Bars front and back (Kit) should come with Links Correct?
Well guys what do you think.
Thats Exactly what I bought for my suspension rebuild. Now would also be the perfect time to replace your power steering gear box with a Jeep Grand Cherokee unit to get the tighter steering feel.
Jeff
Make sure the bushing kit comes with uppers also.
Some sway bars come with frame mounts and call themselves a "kit," others come with endlinks and call themselves a "kit." It is possible to find them with both.
Also, check the conditions of the cross shafts and the pitman arm. Pitman arms don't usually wear out on the chevelle's set-up but they can so check for play.
