1 - 2 of 2 Posts
the guy that owned my car before me didnt put the plug wires back on correctly. how can I find out which way is the correct way? its a 350 small block.
arghh I wish I woulda started learning this stuff earlier
It will be 18436572 and go clockwise. You need to bring # 1 up to TDC and see where the rotor is pointing to on cap and start that with # 1. Pull coil wire and bump motor over with # 1 plug out. You will fill compressed air when it comes up on TDC, Look at the balancer it should be close to 0 degrees. On the motor the drivers side bank is 1357 and pass 2468. Hope this helps you.
1 - 2 of 2 Posts
