i have the wiring right now and the starter has a good ground. The starter is was new but im not sure of its condition now that ive been trying to get it to work with several different shims. With the medium shim the gears looked like they were spaced right but when i turned the ignition i got a clicking noise and the flywheel started to turn just barely and stopped, but all i got was clicking. i tried the medium shim on one side so it would be at an angle and fit a little better but then the starter made a high pitched whine noise and the flywheel didnt turn at all.
what am i doing wrong? very frustrated. i've been messing with these starter probs for a couple weeks now. do i need a starter with a more powerful motor to turn the flywheel?
