I'm shootin for 480ish HP. Do you guys think this combo will get me there?
-2 bolt 454 Block
-Stock cast crank
-Unported 781's with the big vavles (unshrouded)
-Stock resized rods w/ ARP bolts (would the bolts be overkill with cast crank? - I'm thinkin the money may be better spent on the valvetrain)
-Speed Pro .215 dome Hypereutetic pistons
-Lunati Voodoo 60203 cam 268/276 227/233 .542"/.554" 110/106
(May bump up to the 60204 cam - 276/284 233/241 .554"/.572" 110/106 - any input?)
-Stock HEI Distributor
-Performer style intake with Big Q-Jet
-and of course headers with probably Dynomax Ultraflows.
The rest of the combo will be a Beefy 700R4 with 2900 stall through a 3.73 Posi 12 bolt. (I have a 3.42 rear gear availible also - which would be best for mainly street use with ocassional trips to the local 1/8th mile track).
Thanks fellows for any input!
-2 bolt 454 Block
-Stock cast crank
