I've been doing some research on a street 454 buildup. My problem is that the math regarding compression ratios does not add up. Here is what I'm thinking about so far.
454 4 bolt main bored .60 over
Eagle cast crank and "I" beam rods upgraded with ARP bolts standard length.
Speed Pro H581CP60 pistons (summit has the dome at +33.00 cc or .340 dome)
Edelbrock aluminum RPM Rect port heads 118cc chamber
Edelbrock RPM airgap intake
Thinking about a Lunati 60212 cam but will pass it by UDHarold before I order anything.
I'd like to keep the compression ratio between 10:1 and 10.5:1
The rest of the parts are still up for discussion.
I ran the numbers thru Ray Kelly's DCR Calculator and am coming with a compression of 10.8:1. I researched the piston on this site and on the Net and everything I'm reading states that the piston with that combustion chamber should give me a compression ratio of closer to 10:1.
Can somebody please check that I'm not doing something wrong? I think the overbore has something to do with it.
Mark
Mark
