CANN'T FIND WHERE TO ELIMINATE PLAY FROM WHAT SEEMS TO BE FROM THE SPHERICAL JOINT.PLEASE SEND ALL IN PUT ON 66 CHEVELLE SS TILT ONLY.
I just reassembled my 66 tilt column, and the spherical joint is a plastic ball and socket affair with a spring in the middle. That may be broken or dislodged. You will have to dissemble. Make sure you have a 66 chassis service manual in front of you! Good luck!
Frank
66SS396
Just did this in my son's van. Loose bolts. Get yourself a compression tool (or make one, John Muha has a note about it somewhere, involves some electrical conduit thing) and life will be easier.
