I am having trouble with my 7th piston in my 1998 Tahoe. I was thinking yesterday on ways to fix the problem because i already get horrible gas mileage and the fact that the fuel injector is still pushing gas into the piston which isn't firing properly can't help the problem i was wondering is it possible to remove that fuel line and put a straight peice of metal in it's place and rtv the piston shut? I thought this because if i replaced the line to the fuel injector i should just be able to bypass the 7th piston completly and save me a little gas. Will this work???
So I guess you're not really talking about the piston itself, but the #7 cylinder is not firing? I would be trying to figure out why it isn't firing in the first place, instead of trying to figure out a way to disable it.
So #7 cyl is a dead hole??Who diagnosed this?If you have ample cyl pressure and injected fuel..you only require a spark to light off the charge.Based on your post,you have minimal knowledge of how a sequential port fuel v8 operates.That vin R engine uses poppet valves that connect to the injector with a flexable line inside the upper intake plenum.I have no clue how you come up with installing a steel line and rtving a piston shut.Do yourself a favor..spend $90 and have your local chevy store diagnose the misfire before you clog up those expensive to replace cat converters.
Super Moderator
69,
YOu are probably getting horrible mileage because the one injector is sticking open. Find a good shop to fix it for you pronto, before it ruins the engine, then you will really be in for an expense :(
