1 - 2 of 2 Posts
I have removed the bolts from the pinion retainer - but I cannot remove it and the pinion - I can rotate it but I can't lift it out. There doesn't appear to be anything else holding it in place. Do I just need to get a little more aggressive with it?
should come out-if i remember, there is an o ring that makes it tight, plus you have to twist the pinion a little as you pull it out to clear the ring gear-there will be a shim bet the pinion housing and the case
1 - 2 of 2 Posts
