1 - 20 of 21 Posts
Any one with pics of a 2" dropped 67 chevelle?
Anyone with UMI drop springs pics?
Beautiful car JK!
That stance is what Im after. Slight rake with the rear end out of the air.
What is the rest of your stance? Shocks and springs, steering box, sway bars, A arms, tire and wheel combo?
How do you like the power curve of the engine with 3:73's?
How much stall do you use?
Bet the car does rolling burnouts if you want.
Thanks for your help!
Aaron
if you are going to drop the Front by 2" be careful of when you are turning into a driveway/parking lot
that has a little bump up and if you are going to fast, anything other than a crawl,
the Tire will bang up into the underside of the Fenderlip
Here are pics of my 67 before and after
Stock SBC Springs/shocks - Ground to underside of Fenderlip Front = 27" Rear = 26"
FRONT - Ground to underside of Fenderlip with UMI Perf Tubular CAs & Viking DA Coil Over Shocks = 25"
REAR - Ground to underside of Fenderlip with new MOOG Rear Coil Springs # 5385 & Viking DA Shocks = 26"
Reactions: 70CHEVELLE396
Aaron
the Tire will bang up into the underside of the Fenderlip ...
Looks good, what size tires do you have?
Aaron
Classic musclecar stance there!! Looks real good.
Those front coil overs allow you to adjust ride height and get the 1" rake from front to back.
FRONT-Wheel = CragarChrome 391 # 3915734 15"x 7" BS 3.50” BC 5x4 ¾”
---------- - Tire = Uniroyal Tgr Pw RadialP205/75R15Tread Width 6.25” /Side Wall Width 8"/ Dia 27.1"
REAR - Wheel = CRAGAR Chrome 391 # 3915834 15"x 8" BS 4.25” BC 5x4 ¾”
---------- - Tire = M/T Sportsman S/R Radial 28'' x 12''R x 15''LT Tread Width 10.4"/ SWW 12.1"/Dia 28"
Reactions: Pioneer4x4
Thanks Aaron
:thumbsup:
What size and backspace are your wheels? Tire size? Looks great.
Thanks, Al!
My wheels are 18 x 8 front, 4 3/4 backspace. 18 x 10 rears, 6 3/8" backspace. My rearend is an 8.5" out of 71 Cutlass.
Edit...Forgot to list tire sizes. Fronts are 245 40 18, rears 275 40 18.
Thanks, I could tell there was a lot of rubber under the rear, looks good!
Reactions: Kirk's67SS
Thanks, Al!
Thanks for the info. What brand/model are the wheels? Were they custom ordered to your backspace?
Al,
They are Intro brand, "Rally" model. Yes they were custom built to my specs. Not cheap, but very well made. Very happy with them. :thumbsup:
Aaron different pics of stance from post in p1
These fronts are fine, a 7" rim with 235/60/15 wouldnt rub and would look ok
I had 8 in ralles on it before with 265/50/15 they were just right unless you made a hard turn they would rub a little was annoying. 1/2" higher they woulda been fine just cut too much out of the spring. For 15s it handled better than one would think. Almost went 17s but cant afford a 3k set of rims 15s never go out of style
rear 15x8 4.5 bs 275/50/15 MT. If you can find that size in a reg st tire sidewall may not be tall enough
Front 15x5 with MT 26x7.50x15. For the street the fronts drive ok but suck and flat spot if the car sits. Will put reg st tires on the front. Tempted to put reg st tires on the rear just for more tread and puncture protection but afriad of spinning them at hwy spd and wiping out so probably leave the DRs on the rear.
Aaron found a pic of when it had 8" rallyes all around and 265/50/15 up front
For 15s really loved the way it drove handled and really eliminated any rattles etc. Night and day difference over skinnies. 1/2 more height up front would be perfect
Couldnt find ONE aftemarket rallye that was straight after almost 2 full sets gave up and went with current stuff.
Funny thing is cops paid NO attention to the car in this pic. With welds and skinnies totally different story. unreal
My 66 same as 67 for wheels/tires.
1.5" lowering springs. Tires and wheels are 17x9.5 +6 and 275/40/17 both front and rear.
1 - 20 of 21 Posts
