Hi guys,
My first ignorant motor swap a year or so ago. I picked up a rebuilt '68 Hi-Perf 396 which i don't know much about, other than the fact it seems to have a radical cam (registers only a bouncy 7" of manifold vacuum, very hard to tune the holley), not even sure it is still a 396. When I got it, there was an old balancer but wasn't a flywheel. I used the flywheel off my 283 but didn't pay any attention to if/how it was weighted (honestly didn't know about internal/external balancing at the time, still not confident on the subject). It fit, and I wanted to hear that motor run so I re-used it.
To get to the point, I mainly drive it around the neighborhood, peeling tire, having fun, but when I'm out on the highway, I notice a periodic vibration with a shimmy cycle of about every 4 seconds (1/4Hz for you nerds) when holding a constant speed. I don't have a tach, but i'd guess it is about 3000RPM (although I can't say it is exclusively at one RPM). Seems like it has been getting worse over the past few times I drive it.
So I'm looking for some advice before I start taking the wrong path on this. Does anyone have any inputs if this issue seems like a driveshaft, balancer/flywheel mismatch, tuning/timing or just a characteristic of an aggressive big block motor.
Should I seek some professional help on this one or does this sound like something I can debug myself?
Questions about external balancing: Would the balancer have a number which might point to information about how it would need to be matched with a flywheel?
Thanks for your help,
dan
dan
