Question about PCV valves. I don't know how disruptive vacuum leaks are on Carbs, but on a MAP efi it's pretty disruptive!
So I've got my PCV valve plugged into one valve cover, and hooked to the plenum with manifold vacuum.
I've got a breather on the other valve cover.
Isn't the pcv sucking air into the plenum? If so, doesn't that make it a giant vacuum leak? I know the normal EFI setups have a purge canister that is hooked to the other valve cover and the throttle body, making all air in vacuum non outside. It's all "metered" as it was coined to me before.
Just trying to understand more about it, and my lean problem. (see other post.)
How do you know if your PCV valve is fuctioning? Is it the manifold vacuum that sucks the valve open, or the crank case pressure that pushes it open? Right now my manifold vacuum holds it open. If I rev the engine a bit as the vacuum drops the valve closes.
That normal?
Thanks guys
-Paul
That normal?
Thanks guys
-Paul
