Not only do you not need a PCV, but the engine isn't really required eitherblonzz said:It is not raced at the track and only driven on occasion.
So the 4 tall Moon breathers on the valve covers now are adequate?blown70 said:Run 4 HIGH FLOW breathers to vent the crankcase presure and ditch the PCV.You would have MORE than enough vacuum (under the carbs)to operate it but the PCV will suck in oil and that will cause detonation.This is bad!:clonk:
Don't chance the detonation and death of pistons to "make the oil last longer" it ain't worth it.
