Because of the way the carb. sits on the manifold I don't have access to the manifold vacuum port in the manifold. I only have the one port at the base of the carb. for manifold vacuum. I am using this port for my brake booster. My question is can I tee into this hose and use it for my PCV valve as well or will that mess up my brake assist? If not, any other ideas for a place to connect my PCV valve? Thanks.
