Who would like to see Patriot 190's tested against 291 GM heads?
As Mike AKA BigRed point out, by time you pay for valve guides, valve job, mill-drill & tap heads for screw in studs, valves, springs, retainers, locks, cut spring pockets, hot tank, bowl porting and valves you could buy a set of Patriot 190's
So are they gonna make more power, On paper they should.
Is this a good idea? This head can be bought cheaper than doing all the work to double hump heads
Tell me your thought or opinions...
