So, the next item on my agenda for my current project is to replace a partial right floor pan. I have not done this kind of work before but feel confident about it.
My plan is to cut the new patch panel down to a size that is a little larger than the size of repair needed. Then I would mark the floor and grind where the cuts are supposed to be I plan on screwing the new panel to the old panel to hold it in place. I would drill some holes to mark the corners of the repair. Then I was going to take a cutoff wheel or airsaw to cut through both panels. I was going to only cut enough where I can start tack welding the new panel in to the opening. My goal would be to end up having to remove the screws to remove the old piece and the new piece would be tacked in place. Then finish weld and grind the piece.
I'd appreciate any comments on my plan of work. Thanks.
Here's the new panel. Notice it's not welded where the toe panel rolls and meets the transmission tunnel.
Here's the area to be repaired. Sorry for the darkness.
Here's a floor shift hump that I'm going to install too.
