1 - 2 of 2 Posts
It's a 72 Malibu, and the passenger side quarter is jammed good.. It rolls down about 1/4 of a turn of the crank, then stops completely... What do you think would cause it? I would've already pulled the backseat, but it seems like it's stuck (I can't get it clear of the brackets up front) Any tips on the window or backseat? Thanks a lot,
Patrick McDonald
1972 Chevelle
There is something loose, worn out or stuck in the window track and the only way to find out is to remove the backseat and the rear panel. Push down at the front of the back seat and push back (toward the back of car)and then pull up on front of seat. It can sometimes be a b**ch.
1 - 2 of 2 Posts
