Parking Brake cable end clip
281 3
Hey guys, does anybody know where I can get the clip that holds the E-brake cable end to the bracket up on the foot support bracket? (Item #9 View "B" ) in the assembly manual. This project is a 67 SS and I'm converting with all new cables and hardware for the E-brakes. However, the E-brake cables should all be the same drum or Disc, right? The PDF attached shows directly where it goes. I just don't have a Part number for the little clip. Is it really needed? Thanks for any help
Line Font Parallel Diagram Art
Same for both because Disc or Drum they both still use the rear drum brakes for the parking brake or the E-brake whatever you want to call it.
That clip should be used because it keeps the cable attached to the release mechanism making sure the cable stays attached to the E-brake pedal as its used up or down.
