need to know if anyone can tell me if panel between rear window and decklid on a convertible 69 chevelle ..is this panel molded in or should it have seam seal lines between the qtrs and this panel .the hardtops i know these lines are present ,but not sure on the convertible. any info would be appreciated
This seam should not be seen on convertibles. It should be seen on hardtops, etc.. On convertibles, from the factory, I believe this seam is "leaded". I do not know why GM did this different between the two models.
