Gold Founding Member
I am in the process of doing my interior on my 69 the console has faded the console door has faded so some blue is showing through what paint should i use the color is black also what color black is the top stripe on the brushed alum part Thanks mike
You should use Dupli-color plasticote to paint the plastic parts on your interior. The black on the console aluminum is flat black Krylon will work.
Make sure you clean any plastic part with Denatured alcohol prior to painting. This will remove dirt and grease and not hurt the finish. You can get it an any hardware store.
Hey would it hurt if I used Krylon 1613 (semi gloss) to paint the plastic on my console. I was planing to lightly sand it and primer and squirt it? with this work or should I go get some on this other stuff you were talking about? Where do I get that stuff?
