1 - 13 of 13 Posts
Hey, Anyone know the color or paint number Chevy/ GM used to paint/primer on the underside floor of Chevelle body and other GM products? Which was then sometimes covered with under coating. A reddish orange color?
Depends on what plant. Some plants where black, red oxide primer and even body color
Malibu Beater Joe
I believe the Arlington plant was the only one that used the red oxide primer. Sorry, I don't have the paint code. I see people here making reference to using red oxide lacquer primer, also watch out for hue's of orange depending on the brand.
I thought Kansas did too?
@keithb, I dug into my old notes, I don't recall were I cut & pasted this information on the web and who put it together...(unverified)
Primer by plant;
Most common colors found for 70 Chevelle.
Atlanta - mostly Greenish Gray primer.
Arlington -mostly Red Oxide primer (not sure if the bodies were 100% dipped in a bath of this primer?)
Baltimore & Kansas City - Mostly Rosette primer
Flint & Van Nuys - mostly washed-out Semigloss Black
Oshawa - mostly Back primer
*With changes in the assembly line these can vary by plant and dates, the brand of the paint mix and the worker who sprayed it on.
*Shades of these primers may have changed over the course of the year.
*Overspray on the primer could have also changed the color or tint.
1967 Chevelle SS 396 L78 (Sold in 1970)
When my new '67 SS arrived at the dealer, they asked me if i wanted it undercoated and I said yes, so I never saw the underside before they applied the undercoat! But, this is a fact that some dealers did undercoat new Chevelles back in the day! It was a KC build (6-9-67). I believe it cost me about $35! Hopefully, it prolonged the life of the car, but I have no way of knowing.
SPI has a nice red oxide epoxy primer.
They're the best!
I like the black. Get it wet and you see every little ripple in the body. Can be used as a sealer also.
That’s not correct.
1 - 13 of 13 Posts
