This came up on another forum and occasionally it comes up.
Instead of venting out the roof, put a wall vent maybe five feet high for your exhaust fan.
Then where it comes out of the wall where the weather louvers are, put a couple of hooks right at the top of it.
Then get some galvanized sheet metal and make an inclosure, square like heading towards the ground at a angle.
Then get some plywood and a half a dozen furnace filters and make a box so you could set them in it with a couple of inches in between the filters, then exhaust it through them so it blows on top or across your lawn.
Then at night just go out and hang it up on the hooks, I wonder how good a job the furnace filters will do in cutting down the fumes.
Make the metal and wood part separate so you could handle it.
You might be able to get some blankets from a second hand store and cut some square pieces instead of furnace filters, or what would work the best to get rid of the fumes.
I don't have any complaints where I'm at, but I sometimes wonder, anybody got any ideas on this.
Rob
Rob
