Hey all I'm converting my sweep dash to a SS using the Painless GM 18 CKT kit. The 12 pin connector for the dask circuit board is giving me fits!!! I'm using the Gauage SS dash set up and several wires I have questions about. Mainly have any of you all every did this same swap? If so do you have the info by color or the painless numbering system for the 12 pin pushin connector? I know the painless comes without the grounds But I'm still left with sockets with no pins to install. Any info would be a great help.
Gauge option cluster connector.
Connector pin # - Painless wire # - Description.
1 - 937 - Left turn signal light.
2 - 930 - Instrument cluster lights.
3- and 4- See note.
5 - 936 - High beam indicator.
6 - 922 - Oil pressure light.
7 - 935 - Gauge/indicating light power.
8 - 975 - Brake warning light.
9 - 923 - Tach signal.
10- 921 - Temp gauge.
11- 939 - Fuel gauge.
12- 938 - Right turn signal light.
This is for the gauge option cluster standard, indication light cluster is different.
Note: 3 and 4 are for the factory amp gauge. The painless harness is not designed to support it. The amp gauge can be converted to a volt gauge, e-mail for info.
