1 - 2 of 2 Posts
M
Guest
I am adding the above power options to my 71. I got all the harnesses, switches, etc. The only question I have is where do the two 10ga orange wires hookup? They have the normal black GM connector that could fit into the box. These are the 2 that power everything over by the fuse block. I can't imagine they hook directly to the fuse block do they? Am I still missing something from the donor car? Need to know quick before they crush the car. Thanks!
mstacy
The items mentioned should connect to a special power plug. It consists of a #10 black wire one end connects to the horn relay the other to an auto fuse mounted on the firewall. A #10 orange/black wire connects to the auto fuse and is routed through the firewall the end inside the car will accommodate three power accessory connections i.e. power windows, power seat, power top etc.
[This message has been edited by Elree Colby (edited 11-21-2001).]
1 - 2 of 2 Posts
