1 - 13 of 13 Posts
Just bought this seat for my Nova and noticed the over spray. any suggestions on how to remove, its moderate to heavy. looks like primer over spray. thanks in advance.
Jim
I have the same issue with light overspray. I tired a little lacquer thinner on a rag and some of it came off but not all. I would like to know as well.
here is a pic. thanks
Start with a mild cleaning solution like 409 with a scrub sponge, that should soften it up.
Then if it doesn't come up try grease and wax remover, that will most likely remove the rest without hurting the vinyl.
GoJo makes a paint and stain remover for cleaning hands. I would try something like that. There are other brands of hand cleaner for removing paint from hands.
Thanks for the suggestions. i will give it a try
Jim
I think goof-off is a form or diluted acetone and could be a bit harsh. You can try a small spot of out of eye view and see how it reacts.
If any comes off on the terry cloth rag, you should be able to continue.
Just shoot right over it.
1 - 13 of 13 Posts
