ORIG AMP GAUGE HOOKUP
528 2
HI ,
I changed my 67 SS to 1 wire alt system wondering if my orig.amp gauge will work properly or will i hafto change circuit some how ?
thanks
Herm
Herm. I have read that the amp gauge is connected to both ends of the wire that runs from the junction block near the battery (across the radiator support) to the horn relay. It shows the voltage across this wire as an indication of charge/discharge.
If you haven't changed this wire somehow, your gauge should work like it did before.
Hope this helps.
Rob
